Jimmy the Lock
- Jan 4, 2024
- 118
Please provide documentation as to where Kawasaki signed off on using Amsoil.
Amsoil looks at the specs each manufacturer publishes that they recommend for their vehicles and Amsoil meets or exceeds the manufacturer's recommendations
Everyone knows that each manufacturer sells their own parts to make extra money and for that reason they only recommend their parts. This is true for ALL manufacturers, but they cannot void warranties under law if one uses parts that meet or exceed OEM specs.
Amsoli has been heavily involved in racing (extreme duty beyond what a work engine would need) for years and has the experience and know how to manufacture better oil that whoever Kawasaki uses to make their oil which is going to be on the cheap side since the only reason they sell oil is to con people in to believing their oil is what is required when it's not..
If your manual shows an 8 hr oil change
I'll follow what the manual says for the first oil change on a brand new engine.
The electronic keypad even shows the first oil change is due in 8 hours so this is what Kawasaki requires.
You have the right and the choice to believe what you want on the quality or lack there of on aftermarket parts opposed to OEM.
The parts I'll be using are superior to OEM, so you can relax man... I'll get long life out of this engine as do all my engines on all my vehicles.
And from very indicated Owner manual you send the OP to download.
That first graph is for some other engine that has 20.5 HP...
My engine has 23 HP
