dalowryda
- Jun 21, 2023
- 2
I tried halving the mix or there abouts and tried 65:1 with amsoil but it seemed off underpowered/fat/rich. Went back to my normal mix for everything else 90-95:1 and bobs your uncleIf it's one oil I'd trust to run that lean, it's Amsoil. Just read some of their articles.
You can always run it halved. If ur calls for 32:1 run 64:1. It's easy to do the math and use a can specifically for it.
Or, if I feel I'm stretching the mix, I'll use leaded fuel, hoping the lead will do it's job and lubricate. In the years I've been doing that, pistons, chambers, pins and bearings look great. Much much better, cleaner, and less wear than relatives that use cheap oil at a rich mixture.
