On my 01-11-2010 post on the seized Stihl engine, I got it freed up with the diesel fuel in the cylinder advice. I probably poured in too much(about 6 oz.) diesel because it came out from the muffler. I stood the saw up on end(bar down) for several hours to drain it out. The engine turns easily with the spark plug removed, but with it in place I can hardly turn it over...lots of resistance. Was hoping to get it running without taking in for teardown. Is there still diesel in the engine somewhere causing the resistance? Any suggestions? Thanks.
