Question about the mower deck
saber_35
There are 6 to 8 small bolts across the very front of the deck. They are attached to two separate "bars" on the inside of the deck. These bolts allow you to lower the two bars below the bottom edge of the deck. What is the function, purpose or benefit lowering these bars? Can't locate this info in the Op Man.
Thank you,
Jeffrey
mechanic mark
Error click anyway, does this help? I believe you're talking about baffle plates.Baffles click here also
You're welcome Jeffrey.
