AusieAfrikaner
- Jun 10, 2020
- 1
- 1
Hi all,
Intro: I bought my mower 5yearsago in South Africa, Trimtech chassis, 18” single blade with a 650series 190cc OHV Briggs & Stratton motor. On recent years I moved to Australia and now need to replace the blade, initially when i bought the mower I wanted to upgrade to a tri-blade disk setup once required, but due to logistical complications this was not a viable option so i searched for local 18” disk options that would suffice and found a suitable option with the accompanying new Boss.
Ordered online fitted parts and found that the new setup sits about 15-20mm too high up in the chassis. It all works well however im limited in the cut length and cannot cut enough as the chassis starts scraping.
Being technically and mechanically minded I have come up with a few potential solutions, i.e adaptor plats, boss extensions, shaft extensions, however I wantbto avoid adding too much additional rotational mass as The additional weight of the disk is noticeable on startup.
Has anyone else encountered a similar problem and what was the solution you used? I’m looking to use the mower at least for another 5years or until I’m on a larger property where I can justify upgrading to a 19” or larger.
