Pushmower Maintenance
Manny
OK, I do own a Scott's Push Reel Mower. I use it every now and then when I want to cut a small part of the yard on the side of my house. It usually works pretty good for me, but lately it seems like the blades are getting dull. Is there a way to sharpen them?
KennyV
Manny..
If the reel is not too dull you can use a paste grinding compound and lap the edge in on the bed knife... if there are dings in the cutting edges or the edge is really rounded then you will have to use a proper grinder made specifically for this... some of the later made reels were made so the reel can be removed and placed on a lathe to turn cut all the edges at once...
The bed knife is adjustable and often times reversible giving you a second edge... :smile:KennyV
KennyV
I just looked, after posting about using valve grinding compound to sharpen...
Scotts has a sharpening kit...
Hear is a youtube video on how it is used. Looks very handy and easy to do.
YouTube - How to Sharpen a Push Reel Mower: Scotts Classic
I will have to see if I can fab something bigger like that for my Large Toro Gang set...
YouTube seems to have everything... :smile:KennyV
