purchased two trimmers, homelite and mcculloch
Leaking primer bulb can cause a vacuum leak, and prevent the fuel pump diaphragm from working properly.
justin22885
what is a temporary fix for this?.. could i just put a piece of rubber or a thick piece of plastic in place of the primer bulb to sort of temporarily seal up that part of the carburetor until i can get a new bulb?.. i also thought about switching the working carburetor on my mcculloch to the other trimmer to see if i could get it running.. it has an air filter mounted primer bulb though
