Pumping gas into intec 20hp crankcase
ba_50
Just bought this used mower and cleaned the carburetor. It is still pumping gas into cc.
Needle tip looked ok. Does it need a new one? Thanks
Could be the needle, or a hole in the float.
Does it have a fuel pump?
Also post the model number. It will be stamped on the valve cover.
There isn't the usual id tag
Supposed to be 2 years old.
One person put new seal kit in and it stopped.
The model number will be stamped on the valve cover. sometimes on the top of it, sometimes on the side.
Model 31p977
The float doesn't leak but with some force the needle let's air through whether upside down or right side up. Must be the needle or a burr
