I seem to go from one problem to another. Some day I will cut some grass. I have a 2006 yard machine 42 inch 17.5 hp I finally got the engine running smoothly, thanks to you guys, now the blades won't engage. The belt(correct new belt) is loose when the pto is engaged. I carefully check to make sure it is routed correctly. The pulley tension string broke and fell off and I am not sure I got the new one on correctly. The diagram is pretty vague. If some one has a model similar to mine it would be awesome to see a picture of a spring that is installed correctly or if someone can explain how it is connected in terms a real beginner can understand that would be good to.
thanks
thanks
