pulling briggs engine camshaft out of mod 461707 type0145-E1
grasshead8
  • / pulling briggs engine camshaft out of mod 461707 type0145-E1
watched a video on leaking sump engine and removing camshaft to check it. Lined up timing marks on camshaft and timing gear to pull cs out and it came out no problem. Thing is I can,t the cs back in through the lifers. I,m new to all this. Can I get the cs in without tsking the rods out. It came out easy. Briggs&Startton 20.5hp tw20230331_115646.jpgin cylinder OHV
Removing the push rods will allow you to push the tappets out of the way. and you will need to adjust the valve clearances anyway so doesn't require much extra work.
grasshead8
Thanks a great deal. Appreciate it!
grasshead8
I will be doing what you suggested and thanks again, but how is it that the camshaft came out so easy when I lined up cs and timing gear for to dot. Just giggled it out. What changed that I cannot reinsert ithe same way? Can,t giggle it back in? Again I,m new to all this.
mechanic mark
Purchase correct B&S Engine Repair Manual read procedures & follow steps. You will find Manual to be a great investment. Let us know how it goes, thanks Mark
I will be doing what you suggested and thanks again, but how is it that the camshaft came out so easy when I lined up cs and timing gear for to dot. Just giggled it out. What changed that I cannot reinsert itprevhe same way? Can,t giggle it back in? Again I,m new to all this.
At least one valve was being held partially open by the camshaft lobes and since they are sitting on the tappets there is nothing to prevent slipping of the tappets, but the spring pressure will prevent them from being reinserted easily.
