Pulley / Spindle
Sylvain
Replaced a Briggs with a Predactor on my Yardman Rototiller. Shaft is longer that the Briggs and need a spacer in front & rear of the pulley. Is there such an item?
Depending on the how the PTO is design. Otherwords is there a step down on the Briggs where the Predator doesn't have it? If the crankshaft itself is the same at the sump cover then you simply shorten the PTO end of the crankshaft.
