farmerdave1954
- May 6, 2023
- Threads
- 0
- 35
I could have put a new pulley on and mowed half my yard in the time it's taken to read through this thread. Why did you replace the original pulley to begin with?
just a typical cheap made pulley..even the OEM pulley's are as cheaply made.. no quality control any more..I rebuilt the mower deck on my Craftsman GT3000 tractor last spring. After grinding off the rust, epoxying the underside and painting it, I replaced several pulleys, belts, and one of the bearing/blade holder assemblies. Yesterday while mowing, I heard a loud squeal followed by smoke and burning rubber. Pulled it into the garage, and this AM I pulled the deck. The drive belt for the deck was twisted and frayed.
The cause was separation of the top and bottom halves of one of the new replacement pulleys. (See Picture). I bought all of my parts from eBay, since Sears is pretty much gone and has only a few parts available for shipping sometime in this century. Despite paying a bit more for "OEM" parts I have to wonder if the parts I bought really are OEM. After all, the original pulleys and belts on this tractor only lasted 20 odd years. (When I rebuilt the deck, one of the pulleys (not this one) had similarly failed, but it did not eat the belt.)
Is this a common problem? Can I expect a new pulley to also bite the dust in a matter of months? I mow about 3/4 acre every other week during the growing season. The tractor usually logs fewer than 50 hours a year - probably a lot closer to 20 or 30. Note that in the picture I've not started loosening the retaining nut. What you see is what I saw when I yanked the deck.
But....but....there are those here who want you to buy another shitty pulley.....just a typical cheap made pulley..even the OEM pulley's are as cheaply made.. no quality control any more..
Your diagnosis is all wrong. The pulley ripped apart and is beyond saving. Were I on a desert island w/ no access to parts, and had a shop with grinders and welding equipment, then sure, it could be restored if there were no other options. But for twenty odd bucks it is simply not worth it. I have a MIG and could weld it if I thought it were worth while.Nothing wrong with the old pulley. Betcha you can find someone to spot weld it back. Failing a spot weld, there is always the rosette method. Just drill holes through one of the halves and then holes through the other half but offset from the first set. Then any competent welder ( sometimes even incompetent ones) can just weld in rosettes through each hole to bond the assembly. MIG, rod (GMAW or MAW), TIG or gas can all be used. Cheaper and better than new.
Had an issue with clip nuts used to secure items to a seam. Called the company and asked if they made their own. They did and told them to crank up the amperage on the "spot" welder because half of them had the "welded" nut fall off the clip. They called back a couple hours later and said, yup...someone had dialed back the amperage on one of the machines so they sent a bag of new stock gratis.....
After 20 years some of the pulleys' bearings felt dry. I think I replaced 4 of the 6 on the deck. The ones that remained felt fine.I could have put a new pulley on and mowed half my yard in the time it's taken to read through this thread. Why did you replace the original pulley to begin with?
Bullshit.Your diagnosis is all wrong. The pulley ripped apart and is beyond saving. Were I on a desert island w/ no access to parts, and had a shop with grinders and welding equipment, then sure, it could be restored if there were no other options. But for twenty odd bucks it is simply not worth it. I have a MIG and could weld it if I thought it were worth while.
Ok, I admit EVERY inanimate object in life can be repaired. "That's the best durn axe I've ever had. Replaced the handle three times and the head twice".Bullshit.
