Elendil
- Aug 30, 2014
- 43
All this talk about a deck wash system causing decks to rust is nonsense. Some people must be buying awfully crappy mowers if this is happening. If that were to really happen then you better never mow grass that is even slightly wet.
I had a CC for years that had a deck wash system. I used it all the time with no rust at all. Just run the blades for a couple of minutes after using it and it will dry right out.......
