turbofiat124
- Mar 23, 2011
- 288
Is there a reason why B&S does not install pull starters on their larger engines? I'm thinking anything larger than 15hp, like 18HP and up. Is it because an engine of this size would be too hard to pull start for the average person or do they figure people are just getting lazy?
I have a 2010 Craftsman (rebadged Husqvarna) with a B&S 22hp engine and a 48" deck. It has a hydrostatic transmission if that matters. The only reason I mention this is the website below says a weak battery or one with not enough CCA will damage the power take off.
Start-up issues with your mower? How to check your lawn mower battery and pick the right size battery for your mower. » ProGreen Plus Knoxville's BEST Lawn Mower Repair Commercial Mower Repair
HUH? Does this even apply to my mower? Is a hydrostatic transmission and a POT the same thing? I thought a PTO was an yoke attachment that spins that came out of the rear differential on a tractor you could run a mowing machine or some other implement off of.
The battery on my mower has just recently bit the dust. It went flat over the winter so I recharged it in May when I started mowing this season (yeah really) and it actually held a charge for a couple of months until the other day when it went flat again. I gave it a quick charge for about 30 minutes then mowed for about 4 hours. I don't know if four hours was sufficient to charge a battery or not. Or if the dynamo has enough amps to actually recharge a dead battery.
As I normally do, I let it cool down before pulling into my yard barn. After sitting for a couple of hours, the starter struggled to turn over but it did start. The next day the battery was flat.
Since I am almost halfway through the mowing season, I'm thinking about just giving it a quick charge before mowing then come next spring I'll replace the battery. What's weird is, the date on the battery says Oct 2010, yet I purchased this mower in the May of 2010. How is that possible?
I've noticed that batteries are getting more expensive and the quailty is going downhill. I remember just ten years ago you could buy a cheap car battery for $30 that would last 7-10 years if you kept it topped off with demin water. Now a $110 car battery has a 2 year pro-rated warranty and you are lucky if they last three years.
