Pull start tries to pull my arm out of it's socket
carpespasm
  • / Pull start tries to pull my arm out of it's socket
Okay, so after a replaced flywheel key, intake manifold, adjusted carb spring, cleaned carb, rebuilt pull starter (which in retrospect I might not have needed), and lots of assembling and disassembling this thing IT'S WORKING!
Thanks for pointing me in the right direction, and if I may say, getting a gear puller to pull the flywheel worked so much better than trying the hammer method, and was much less hair raising. Need to do a little adjusting and put a new blade on it, but she'll mow another yard now thanks to you guys!
SeniorCitizen
I'm done wasting my time. I said to leave the nut on the shaft.
kkelly311
Did that fix your problem?
