Neither the blade or drive lever will cause the engine to smoke. Generally, smoke is due to a bit of oil in the cylinder. A puff or two is no big deal. If it continues to smoke a lot after getting warmed up, that could mean problems internally with the engine. Either a crack in the block, worn cylinder walls or ring, etc.
