I have a Grasshopper mower. When the mower is cool, the blades will engage. When the mower is hot, the blades will not reengage if I stop them for any reason. Also, the blades will stop working on occasion if the mower is run over deeper grass. Then they will not reengage.
Suggestions for areas that I can check for problems.
I checked the fuses and they were good. I can hear the PTO whirring but the blades do not engage. It is possible the PTO clutch is bad, but I don't know how to determine that.
Suggestions would be appreciated.
Lin
Lin
