Repairs PTO switch Cub Cadet 1650
tom3
There is a bearing in there somewhere. Does it turn smoothly when not engaged?
NorthBama
if it has the 3 adjustment nuts it comes apart to look at the plate. I would remove it from engine and take a look see
BRogers03909
It has 4 adjustable nuts. Can I remove this plate without removing the pulley?
NorthBama
Here is a picture i dont know if it is like yours
NorthBama
That looks like an ogura clutch not sure if you can purchase individual parts. May be best to buy new replacement. Does the clutch still have the part number sticker on it.
BRogers03909
I will have to pull it off first. Is there a torque level it has to be when I put it back?
NorthBama
yes there is a torque setting not sure what without a manual. A new one comes with torque number if you go that route.
BRogers03909
Ok so it looks like I need a new coil for this clutch. Does anyone know if I can get just the coil, or get this one rebuilt? Also , where is the best place to poke, pry, hammer to get the last piece of this assembly out? The rest of the unit looks brand new.
82C6675B-F09D-4CDC-AC63-C167FF6D5F43.jpgD28A5793-5FFC-43A0-980F-B1FC9D9BCD26.jpg82C6675B-F09D-4CDC-AC63-C167FF6D5F43.jpgD28A5793-5FFC-43A0-980F-B1FC9D9BCD26.jpg
