PTO Rod Keeper
CubDriver
I have a Cub Cadet LGT1054. I am replacing the mower belt and have a question about putting back the PTO rod keeper. The illustration in the Cub Operator's Manual, page 24, shows the rod keeper inserted in a notch on the upper wheel (clutch?). I don't remember it (the rod keeper) being attached when I took it apart. Does the rod keeper go into a notch on the upper wheel? I can't find any info in the manual.
BlazNT
Something from the mower has to go into one or the 2 slots or hole in the picture.
BlazNT
upper wheel (clutch?) is the PTO where I put the circles.
Generally it will be the drive belt keper that the clutch slips into.
CubDriver
Thanks for your help. Mower is back together and ready to cut some grass.
