RECENTLY BOUGHT 2013 GRASSHOPPER 930D2. Dies when I engage blades. Have noticed when under it putting new belts on PTO that i can hand-turn the drive shaft to deck, and it turns smoothly and then stops, reverse direction ditto. No metallic noise, just stops. Thought odd, but figured when running would work ok. I saw the mower mowing before I bought it. All fuses good.
Can deck blades be turned freely by hand when power off as long as deck not raised very high?
Does PTO clutch allow deck drive shaft to turn freely with power off, like just grabbing drive shaft and turning it? Another comml mower I have, A Toro, can do that as long as PTO not engaged.
