PTO Issues - 72" Turf Tiger II
SmallTexasFarm
@StarTech I've read a few threads where you've been incredibly helpful so I hope you can point me in the right direction.
We have a 72" Turf Tiger II with Vanguard EFI 37 (37BV-EFI) and the PTO stopped working so I chased the 12v signal and found the connectors between the main wire harness and the clutch had melted together. This is odd because it made enough heat to melt the plastic but must have stayed below 20A since it didn't pop the 20A fuse. I cut the connectors, trimmed the wires past the damaged area, and added a new connector making sure to keep the two identical green wires straight (i keep red and black electrical tape just for this). Tested everything out and it was working. I put off investigating the cause since I had 10 acres to go mow.
The next morning when I took it out, the 20A fuse started popping as soon as I pull the PTO switch. I tested pulling the switch with the clutch unplugged and that doesn't pop the fuse so either the clutch is fried or I somehow swapped the wires. I also checked the resistance and get .4 ohms at the tips of the green wires and 1.1 ohms if I probe them up next to the clutch so I'm assuming it's toast and yes, I touched my multimeter's tips together to make sure it's still kicking.
I don't want the issue to be a clutch, but I'm pretty sure we need a new one. Your thoughts?
Never ran across a bad clutch yet , if your wires were crossed it wouldn't have worked after your repair ,
You still have a short to ground somewhere, Disconnect at your new connection , hook up to a test light and engage the clutch switch and see what happens , it will point you in the right direction for trouble shooting
