i just joined this forum and am hoping i can find a salution to my problem.i have an
'09 troy-bilt pony riding mower that is having an issue when i try to crank it.i've replaced the switch under the lever with a new one and taken the cable off to lube it inside and reinstalled it.when i do crank it again it still acts as if the pto lever is in the forward position.it also has new belts on the deck and drive pullys.i hope this is enough information,if not then please let me know,thanks in advance for any forthcomeing info received.
