PTO clutch replacement
BrentW
I will get a new xtreme clutch tomorrow and it has a set torque value to hit. I have a TC 2 with the Kohler 29 EFI engine and was wondering the easiest way to hold the crankshaft when torqueing the bolt. It has the thick washer and no D spacer.
On that Kohler ECV860 the way I can see is the remove the shroud and speed sensor. don't want take a chance damaging the sensor. Then insert a large flat tip screwdriver into the flywheel teeth and while holding the screwdriver up against the speed senor post torque the PTO bolt. A lot easier with a helper.
Now bear in mind that I haven't seen this ECV860 in person yet so I am just taking a guess at where to do this but the speed sensor post looks like the likely choice for bracing the screwdriver.
Old farts and farmers method. Remove a spark plug and thread a piece of cotton rope into the cylinder. Keep the loose end out to remove later. Rotate the engine slowly by hand until it stops. You can now tighten the PTO bolt. After tightening rotate the engine backwards until the rope is free and pull the rope out.
But you must make sure both valves are closed or you risk damaging one when using the rope trick.
I have a set of torques sticks I use but set did not include the 55 ft lbs. some clutches recommend had to buy it separate
