Pto clutch rebuild
sky89vette
can a pto clutch be rebuilt. it is drawing too many amps. Bench tested 7.25 ohms any suggestions?
Doubtful - I'd look at a replacement - never seen one go bad but sure it can happen
Unless you can find an electric motor rewinding shop that is willing to build a new coil. it is not repairable. And most electric clutches don't use standard size bearings even if the number on the bearing seal leads to a standard bearing the bearing may not be standard.
