How old are the fuel lines from tank to carb?how old is the fuel?
Bad Boy does the same....almost. Before fully warming up must use choke briefly. Full throttle to engage blades. I have a soft start on the blade clutch that really eases the clutch into full engagement. If you engage at less than full....yes it bogs down.61" Ferris IS3000Z Water Cooled FD731V Kawasaki 25hp. This motor only starts on full choke and highest rpms. The PTO also only works when engaged with the highest rpms. This problem just started. When I engage the PTO the motor dies. If I quickly shut off the PTO and engage it again it works but the blades aren't spinning fast and the motor is chugging down. I took the belt off and tested the pulleys and spindles. All spin freely and no wobble. With the belt off, the PTO engages just fine and spins without wobble. Any ideas what could be going on?
It is the coil. Left cylinder isn't firing. New plugs. Swapped right plug with left and still no fire. I bought a new OEM coil and installed it, gapped with a business card. Still no fire. Both coils test good with a multimeter. I think I must have a dead short somewhere but can't find it.This favors a cylinder that is not producing power. These engines do not vibrate due to internal balancing and they are solid mounted.
My guess would be spark plug or coil. It may also be a dropped pushrod, and a valve is not working.
They are old. It is the coil. Left cylinder isn't firing. New plugs. Swapped right plug with left and still no fire. I bought a new OEM coil and installed it, gapped with a business card. Still no fire. Both coils test good with a multimeter. I think I must have a dead short somewhere but can't find it.How old are the fuel lines from tank to carb?
It is the coil. Left cylinder isn't firing. New plugs. Swapped right plug with left and still no fire. I bought a new OEM coil and installed it, gapped with a business card. Still no fire. Both coils test good with a multimeter. I think I must have a dead short somewhere but can't find it.Bad Boy does the same....almost. Before fully warming up must use choke briefly. Full throttle to engage blades. I have a soft start on the blade clutch that really eases the clutch into full engagement. If you engage at less than full....yes it bogs down.
It is the coil. Left cylinder isn't firing. New plugs. Swapped right plug with left and still no fire. I bought a new OEM coil and installed it, gapped with a business card. Still no fire. Both coils test good with a multimeter. I think I must have a dead short somewhere but can't find it.the next thing would be to look for a vacuum leak. There are engines that have, for example plastic intake manifolds, that can crack. The symptoms you have listed are either lack of fuel or too much air. Bad fuel acts the same as lack of fuel. See if the engine runs better with the choke partially on. Also - a clogged main jet can cause that too, as can debris, a clogged fuel filter, etc.. I would also run a compression test on both cylinders because sometimes low compression can show up as mixture problems. At low compression the air molecules are farther apart.
