cruzenmike
- Feb 10, 2017
- 59
- 858
After rebuilding a couple of Nikki carbs in Briggs engines and having to replace various rubber o-rings and gaskets that failed from what is likely ethanol exposure I have switched to ethanol free in all of my equipment. As of right now it is $3.89 a gallon. I did a comparison of running e10 with ethanol shield and running e0 and it was less than 50 cents per gallon difference. I consider this to be negligible so why deal with having to mix in additives. I also keep 10-15 gallons of e0 on hand at all times and rotate the gas every 6 months regardless so I should never have a supply issue within my own garage.
