Product Safety Recall: Honda FG110 Mini-Tiller
robert@honda
SAFETY RECALL NOTICE: FG110K1AT Mini-Tiller THROTTLE CABLE / ENGINE STOP SWITCH WIRE PINCHED
Affected Model Serial Number Range:
FAAA-1200001 through FAAA-1540521
Units previously inspected/repaired, identified by a “green dot” located on the carton, are no longer affected by this recall.
Before using your mini-tiller, inspect the throttle cable and engine stop switch wire for damage caused during factory packaging. If damage is found, do not attempt to use your mini-tiller before repair. Contact your local Honda Power Equipment servicing dealer to have it repaired free of charge.
What is the problem?
Due to a packaging error at the factory, the throttle cable or engine stop switch wire may have been pinched between the upper and lower handle pipes when the handle was folded for packaging. If the throttle cable or stop switch wire is pinched as a result of the factory packaging error, the tiller tines may immediately begin to spin upon start-up or the engine may not be able to be turned off.
What should you do?
Please contact your local authorized Honda servicing dealer for inspection or repair. For more information on this recall or to find a dealer near you, contact Honda Power Equipment Customer Relations at:
888-888-3139 or visit our website at: powerequipment.honda.com
This recall is being conducted in cooperation with the U.S. Consumer Product Safety Commission.
