Not to be duh, but a motor runs on 3 things: Spark, Fuel, and Compression. I always check for a spark first, its easy to do. No spark, start looking for the safety switches, and if all are being made you have to dig deeper. If there is a spark, then I run a compression test. You should have at least 100 psi, if not....... While you are in the vicinity, set the valves. When you take off the rocker cover, the exhaust is the top one. Set the intake at .005 - .007. The exhaust gets .010 - .011. Then its the fuel testing time. Go through the carb, use some Gunk or a good cleaner. At least 80% of all the repairs I do involve old gas, carb deposits, plugged main jet.:smile:
