Allwxrider
- Mar 7, 2015
- 2
I took the carb off to clean out the bowl...but now the linkage is amiss. Lever slides to choke OK, Full Throttle OK, but when I try to move to idle, it binds. I was thinking that the dropdown section of #10 linkage is a spring, but it does not give.
Is this a fixed throttle engine??? Two parts stop the control cable from going to idle: part #10 the rubber grommet & the rotating cam #7.
