Have a push lawn mover with Honda GCV160 engine. The mower has proper amount of oil in it which is two seasons old and not dark so seams ok. I left the mower over winter with premium gas (half tank) in it. Darn, I should have properly winterized it and emptied the tank.
Now I can't pull the string. Nothing is stuck with the blade. I can rotate the blade with hand but it's not rotating easily and also it gets harder to rotate after a little bit of rotating, it releases, and then the same thing happens. I removed the spark plug and then I could pull the rope but rotating the blade is still the same and a little hard. The spark plug seems normal with no sign of oil or any other dirt on it. I read somewhere to add a little bit of penetrating oil and I added a bit of WD40 into the spark plug hole. Let it sit overnight. I tried again in the morning and it's the same thing. Any idea what could be wrong and how I can fix it?
