Pro z 100 deck hight issue
LVFlier
Hey group, I have a pro z 100 with the 54in deck. I recently took the deck off to do a full spring maintenance. I changes the belt blades ect. The issue that I can't seem to figure out the deck hight is 1/2 low compared to the beck hight setting. The deck is level the tires are properly inflated everything else looks good. Any thoughts or suggestions would be great this has never happened before? I set it to 4in the blades are at 3.5. I am a novice so it might be something stupid
Thanks
LVFlier
Numbers are not inches
On some mowers they over come this by using letters
