Mad Mackie
- Jul 11, 2011
- 1,851
My Scag Tiger Cub came with a 26 Briggs Intek/ELS engine. At around 400 hours it started to sneeze at idle. long story short it had stuck rings on the L/H cylinder as a leakdown test indicated. I decided to replace it with a new 30 HP Briggs Professional Turf Series engine as this was the most economical direction to go. As I had the two engines together along with their parts manuals, I compared items as best I could without tearing down both engines. The first thing that I noticed was the intake manifold on the Pro Turf engine was an aluminum casting as compared to the plastic one on the ELS engine. Some of us are aware of the problems with the plastic manifold and I had replaced the one on my 26 ELS engine. The cooling system was much larger, the Cyclonic Air Filtration System looked to be a great improvement and I took it all apart to look it over. There were some external crankcase differences indicating internal changes which the parts manuals also indicated. These engines now have an engine oil cooler located where it gets some of the incoming cooling airflow passing thru it. This engine now has about 120 hours on it, it would have had more, but I am gradually decreasing the number of customers that I have and with the changeover to mulching rather than collection, the operating time has decreased. I'm pleased with this engine, it uses less fuel than the former 26 ELS engine and by far fewer air filter changes needed. At 100 hours I switched it over to full synthetic engine oil of the Briggs recommended viscosity. The oil consumption has stabilized, although wasn't very much, and without having to stop and empty the collection bags, I have operated this machine engine nonstop for up to 4 hours, and then only for a potty break or a refuel!!!
Bear in mind that I also have a Vanguard powered Ingersoll GT, an Intek powered wood chipper and a Hustler X-ONE with a Kawi FX730V engine, and I do limited service on power equipment, mostly generators in the last few years with the storms and power outages that have become more frequent.
Mad Mackie in CT:laughing::biggrin::smile:
