primer bulb
JDDK
Got a Bolens cultivator/tiller. Mice/rat(?) gnawed primer bulb. can this be replaced? A quick look did not show a readily apparent method. Great little cultivator but sucks air with primer bulb holed and will not start.
The primer bulb is replaceable... Bolens has made several different model cultivator's... you should not have any problem locating the part & replacement video clips are on youtube. :smile:KennyV
Thanks! Rechecked tiller and saw how the bulb is replaced. Part on order. Thanks again!
