gregdavidson
- Aug 6, 2015
- 1
- 2
I own a Murray lawn mower with a Briggs and Stratton engine that I purchased from Walmart for about $150. It closely resembles the lawn mower at the link below. When I press on the primer bulb, it doesn't fill up with gasoline like it's supposed to. After closer inspection, I realized that the gasoline that's supposed to be going in the primer bulb is actually squirting out of the side where I believe a cap or tube used to be. I'm guessing this part fell off the last time I used it. Do you think this is the problem? And if so, which part am I missing? The lawn mower has been sitting in storage for about 10 months.
Murray 22" Gas-Powered Lawn Mower - Walmart.com
