bones66
- May 3, 2011
- 4
- 42
Don't know if were talking about the same species of ants but I've had good success with the Terro products. One exception is the sprinkle barrier granules you sprinkle around a perimeter or foundation and then water it in. The indoor product comes in a small plastic bottle. Tear off the little squares on the package and put a few drops near the ants and continue to feed for a few days. The parade will increase (and I mean increase) as they tell the colony and you will need to keep adding drops to the squares. Supposedly they take it back to the colony and it kills the colony including the queen. The package says it's not poison so we used it on our kitchen counters. It is borax and a solution of liquid with a sweetener added. They make a bait station with the stuff for outdoors. It appears that it's the same solution only in weather proof containers. I did see a mixture for borax and sugar water somewhere on the net. You might do a search and find it. The down side to this produce ...time, because you're allowing the feeding insects to take the bait back to the colony it's not an instant kill. We fed one colony for probably 10 days total. The last 3 there were only stragglers appearing. We wanted to kill them all and the little square bait stations were placed inconspicuously so we allowed them to feed. Over a month and not a single ant. I'm not against poison at all but this seemed to me the better alternative. I had two other areas where they were trailing up the foundation and I used the outdoor packages for them an they are no more! Worked for me!
