Export thread
Pressure Washers
#1
OUTDOOR CONCEPTS
OUTDOOR CONCEPTS
We use these around the shop quite a bit. Would you rather use pressurized air or water to clean out your deck? seems to be split around the shop.
New 3000 PSI Pressure Washer 2 7 GPM 190cc 6 5 HP OHV Briggs Stratton Engine | eBay
#2
davbell22602
davbell22602
Pressure air. I'd be concerned about water adding more rust to the deck than whats already there.
#3
OUTDOOR CONCEPTS
OUTDOOR CONCEPTS
Good man, air all the way. Some of the old school guys just want to use water, I guess old habits die hard.
#4
davbell22602
davbell22602
I use air hose or gas hand held leaf blower to clean the grass off on my mower decks.
#5
exotion
exotion
Compressed air. Pressure assures can force water into and past seals and bearings
#6
OUTDOOR CONCEPTS
OUTDOOR CONCEPTS
Nice thought on the blower!
#7
metz12
metz12
yes, compressed air is you best bet.
#8
Carscw
Carscw
I blow my mower off with my blower after every yard. When doing weekly service I use compressed air.
I think it's funny guys use a water hose to remove the grass from the deck so it will not rust then put the mower in the shed wet.
#9
metz12
metz12
right? i see people do that all the time.
#10
davbell22602
davbell22602
Those people will make us rich in time when they looking for another mower deck cause theres is rusted out.
Note to self: Start stock piling mower deck housings for the ones that wash theres with water.
#11
exotion
exotion
No these are the same people that will just buy another cheap mower lol
#12
metz12
metz12
or get an mtd deck for a craftsman and want us to put it on theirs because they got the deck for like 10 bucks at the scrap yard.
#13
Ric
Ric
I do the same as you, I blow off the entire mower the after ever yard including the drives. I just do it with the blower. I don't like transferring crap from one yard to another. I only pressure wash once a year at the end of the season and never under the deck. When I do Pressure wash I leave the engine running and run everything until it's all dry.
#14
OUTDOOR CONCEPTS
OUTDOOR CONCEPTS
GOOD CALL!
#15
wjjones
wjjones
Yep same here I dont like all that water setting rusting everything out. I blow the major stuff off with the blower, and finish it with the air compressor. If you wet it, and dont get all the grass off then it acts like a sponge holding the water in all those spots you dont see until its to late.
