Boobala
Actually it is different. The water is the lube for the pump. Now if there is water in the pump and you shut off the water supply, start the engine and then turn the water on it will buy you a short period of time. If you have seen how many warranty claims I have to deny because somebody turned on the water but didn't bleed the air out of the hose to the pump and actually melted the white plastic washers that hold the seals in place, stuck them to the pistons and then strung melted plastic through the pump you wouldn't start yours without the water turned on and water flowing from the gun.
AND even the BIG BOYS of commercial outfits will tell ya, it's better to start the engine while squeezing the trigger with the water turned on to bleed the system and to ease the starting process.
