PP4218a chainsaw carb adjustments.
1947
What is the starting adjustments after repair for a Poulan Pro chainsaw modal #PP4218a? I had it running but it wouldn't idle. so I started adjusting the L & H adjustment screws and now it won't start.
So how many turns should I back them out after running the in all the way?
The old adjustment used to be 1 turn out, but some of the newer carbs run 3 turns out. So it is a guessing game.
Boobala
Doesn't the carb have an IDLE screw ?? ....... separate from the Low/speed ...High speed jets ...??
primerbulb120
Moderator
I'd try 1 1/2. If that doesn't work, try 2.
This carb has a separate idle speed screw, but if the mixture isn't adjusted right it won't idle no matter what you do with the speed screw.
1947
1 1/2 allowed me to start and make needed adjustments. Thanks to all!
Boobala
AND WE thank you for posting the outcome...it may help someone else down the line ... Boobala
able43
Just helped me, thanks and all the best
