ThatGuyYouKnow
- May 1, 2013
- 17
- 60
Okay friends this has been smashing my head for a while I have a Poulan Wild Thing P4018WM with Zama carb that will not run right. It wont start on full choke it will start and run at a fast pace on 1/2 choke and wont run or crank on no choke. Once running you can ease up on the throttle and it will rev nice but as soon as you top out it bogs and dies and if you leave running after the trigger has been clicked when it swaps to no choke it dies. Please help I have checked the fuel lines bulb filter all good I checked the diagram it appears good no cracks or tears made sure all sealing areas are good as well.
