Ive got a poulan 42" with 18.5 Intek B&S. This spring, I replaced the solenoid when it would not start. Seemed to fix the problem, until three weeks ago. It will not start now, unless I jump the solenoid. I have put in another new solenoid(parts store said it should not be bad again, and I agree). With new solenoid it will not start. I get power from the battery to the solenoid but not out of the solenoid. I can still jump the solenoid and start it, but that is a PITA way to do it if I have to go inside or move something out of the way. I havnt changed the ingnition switch, but have put a new fuse in just to make sure. ANy ideas of where to go next. Thanks for the help in advance.
