Poulan PL 3314 Chainsaw
MyBillyC
Has anybody crossed paths with this model and if possible, does anybody know what it is cross referenced with in this conglomeration of makes? Any help would be appreciated as I am coming up empty.
well it uses the 530017884 non plated cylinder with a 530017883 NCC piston which is use in the following models too. Basically it has a Poulan 42cc engine setup.
PP4018 PP3516AVX PP4218AVX PP4218 P4018WM P4018WT P4018WTL PP3516 PP3816 P3314WS P3314 P3314WSA P3416 PP4218AVHD S1970
Note you can not have a NCC cylinder and NCC piston at the same time; just will not work. It got to be either a NCC cylinder and plain piston or a plain cylinder and a NCC piston.
Your reply is much appreciated. The saw was brought to me due to what appeared to be a fuel delivery issue. I tries searching this model number ay all of my usual places and came up dry. Now, I know the associated models to order parts needed. Thanks again, Bill
Again, thank you for your help. I'll keep this info since I've seen a number of these saws badged as Craftsman, Homelite, etc. Bill
