-<Sparrow>-
- Apr 2, 2017
- 0
- 1
You may want to check the Fuel/Air needle settings on the carb. In particular, if it's not revving high or smooth enough then the H needle may require adjustment. The L is for idle only. The factory setting on these may need tweaks over time due to vibration, wear, and abuse. Good Luck.
