Not sure if this is the correct forum, but has anyone tried this mod? I tried to install the bearings and thrust washers while I was replacing the drag links and installing new steering spindle bushings. Once I installed the bearings and thrust washers, I couldn't install the e-clips with the washers. That didn't seem safe to me, so I removed the bearings and thrust washers.
Did I do something wrong?
Thanks
Thanks
