This machine has the Kohler OHV. Motor runs great - rebuilt it two years ago. Rebuilt deck as well, most electronics replaced. Fuel system replaced. Has run well for a good while.
Was mowing last week and PTO shut off about 10 minutes into the mow. Motor and hydraulics continued running fine. Ran the mower back from the field to the house and shut off. PTO is very hot to the touch. Went to restart the mower and would not start. The starter clicks and attempts to turn the motor, but it is as if the motor is being prevented from turning. After everything completely cooled, same result - starter attempts to kick the motor but no advance. Note the mower ran fine after the PTO shut off. Deck spindles/pulleys turn freely.
Battery full charge, PTO checks at 2.5Ω so not shorted. PTO switch seems fine (continuity when raised for engagement). PTO clutch is original. Any ideas?
