What kind of a "plow" are you referring to? Is this a breaking plow such as what you would use to turn over a furrow of dirt, or are you wanting a snow plow? If you are wanting a breaking plow, then you'll need the sleeve hitch that I linked for you and it will mount on the rear of the tractor. However, if you're needing a snow plow, then a front mounted one will probably work best. They should come with their own mounts. If you live in an area that doesn't get a lot of snow, like here where I am, then a rear mount grader blade will do just fine. I have a grader blade for my Snapper, it works very well for our occasional 2-3" snow, and even works for our rare 6-8" snow too.
