Please help, need BELT DIAGRAM: Snapper 48 pro walk behind
  • / Please help, need BELT DIAGRAM: Snapper 48 pro walk behind
I figured out the belt, ill post a photo later for a diagram in case anyone else needs it in the future. Thank you everyone
You must remember we may be thousands of miles away from your location, without a strong drink in hand to see your exact unit. We can only base our replies on the info and pictures you post. Even as experienced techs at this point we can only make guesses at this point. Star guessed a SW30 model and I guessed an SW20, I think one of us is correct, but remember they are only guesses. Most Snapper units have a silver ID tag riveted to the frame, somewhere around the handle area. If you really want help us help you, you must work with us. The manual I posted has two different models, depending on the engine HP. Please take a third look at your unit and see if you can find any silver ID tags. If you post back and can’t find a unit ID tag, include all engine numbers and an exact width of the deck and we’ll try to help you by using a couple or backdoor methods.
Thank you for your detailed response, I’m coming back after i finish my bushhogging
hlw49
A simple rule of thumb is flat side of belt to a flat idler and v side of belt to v idlers.
