PLEASE HELP ME! I've been told I have bad gas... but about my Hustler SuperZ60"...
dr1234
:biggrin: we have a 5-year-old super Z that we had serviced by the local company we bought from until they moved two years ago. Last year I got a grease gun, took off the deck and sharpened the blades, & changed the oil, and hydraulic oil myself. Everything went fine last year... We use our mower through the winter as well so I really didn't add any gas additives... This summer when we started using it on a regular basis after the first use started missing out for the next couple cuts and losing power, now there's a huge power loss... I had been told by one neighbor he thinks it may be a gas gumming issue, I'm not so sure it's not belts, or something else... Any recommendations from the pros out there? Any quick replies would be greatly appreciated
Re: PLEASE HELP ME! I've been told I have bad gas... but about my Hustler SuperZ60"..
Not familiar with that particular machine, but would check a few things.
Air Filter - may look clean and still need to be changed.
Fuel Filter - may be clogged.
Try some Seafoam or Gumout fuel system cleaner - Any similar product should clean out the system if it runs.
Spark Plugs ?
Adjustments on belt tensions etc.
Have you checked the Hustler web site ? They may have a troubleshooting section or even a help line that might be able to narrow down your problems and offer suggestions.
Just about any manufacturer today recommends the use of a fuel stabilizer. The gasoline has more light factions, etc. in it, which while allowing more gas to be produced from a barrel of oil, results in quicker deterioration. Generally not a problem for cars that fill up every week (although I wonder about hybrids). I've used a fuel stabilzer (StaBil) every time I buy gas, summer or winter for the mower. It takes me more than 30 days to go through 2 1/2 gallons. There is now a product that you can add after the fact, just don't remember the name, maybe "fresh-start."
If it has the Honda GVX530 you have valve problems. If it will run good for a few minutes after a cool down and draining the gas from the carb---back off the drain screw at the side/bottom and allow the carb to empty. If it is cutting good and thens starts losing power the valves are stuck. I always use ethanol treatment, Stabil, and Sea Foam but it didn't help this Honda.
