Shughes717
- Jun 12, 2014
- 4
- 1,230
Hi Steve >< I bought a Toro Z Master 3000 ( Which is Just about the same as a 2000) with 52 in Deck last June, I now have 120 hours on it, I cut 4 ac. with it and have had no trouble at all, I went with the 52 in. Deck because of some of the tight place I need to get in to, this mower replaces 2 JD Riding mowers, I had a JD LT 445 with a 60 in. cut and a JD LT 160 with a 46 in. cut, I had to have the smaller mower to get to places the Larger mower could not get to, this mower is able to take care of all my mowing needs
Rat
How long does it take you to mow that 4 acres LakeRat1? I bet you cut your time in half when you went with the zero turn.
