polarisgold
- Jul 18, 2012
- 13
- 38
Well, I've spent most of the week working on this mower and got everything together and gave it a try. Fully expected to hear those newly sharpened blades mounted on new spindals to hum!!
Not a chance! I could barely hear them, I thought those new spindals sure are quiet. But once I got in the grass it stopped cutting.
I have a 1995 Dynamark B&S 12hp riding mower with no chassie label or manual. I made the mistake of buying it used. It has a two blade deck. I found two different diagrams that showed the blade belt running around the blade pully's and going on the inside of the tension pully and off to the engine pully. The pully's on the new spindal's are the same diameter as the old spindal's so I do not understand whats wrong. Before the blade/spindal problem it worked fine. It seems to be struggling to get up to speed. Belt not tight enough I guess.....but no idea how to tighten it.
Any Idea friends?? Suggestion's or advice will be accepted!
