Piston ring replacement, need help
arch252
Replacing the rings on a FD501V liquid cooled twin cylinder 17 hp Kawasaki off an LX279. Looking at the parts list on both the JD catalog and the Kawasaki catalog, both show to be using 5 rings, the oil ring with two rails, a top ring and a bottom ring. I ordered the JD ring kit, part #M144034. Has 5 rings in it.
I removed the piston. There are only 4 rings, the oil ring with two rails and a single top ring, no second or bottom ring. There is a shallow groove in the piston between the top ring and oil ring, but it is not nearly as deep as the ring grooves. What am I missing here?
I suspect that Kawasaki did a running part change of the piston ring set, and the replacement parts go to the newer part used, and they expected the rings to be replaced with the piston.
arch252
So I guess I'm dropping another $70 on pistons.
I would say there is a good chance you will need pistons. Just be aware that there was another engine manufacturer that changed to mahle pistons several years ago, from another piston manufacturer that used a smaller wrist pin diameter, which also required you to purchase new rods.
arch252
Oh brother, I hope that's not the case here!
arch252
Well, you hit the nail on the head. JD replaced the two ring piston with a 3 ring piston. Would have been nice of them to show that as a replacement on the parts list. Took the service tech at Trigreen a minute to figure it out as well. Fyi, anyone with this same issue who does not want to replace the piston can get a two ring set for an LX188, same pistons on the original LX279. I went ahead and replaced the pistons with the 3 ring. Got it together today and started it, no smoke at all. Pistons, rings, case gasket and oil seal...all told about $220. Didn't plan to put that much in it but it sure runs nice now. Anyway, thanks again for the good info.
7394
FYI: If one ever has to change pistons to to ones with a smaller wrist pin, most competent machine shops can push out the old wrist pin bushings & turn out some new re-sized ones.
That has to be cheaper than splitting the cases & switching rods.
